I stumbled upon this video which was posted on YouTube a few weeks ago...
https://www.youtube.com/watch?v=vlSlPVoY-wE
It's a Dutch TV report about the problems owners of Audis, fitted with the 2.0L TFSI petrol engine, have had with excessive oil consumption. Now I'm well aware that this is an old problem and that Audi have stepped up to the plate to fix these cars.
However I was really interested in the part of the video where someone empties a box of 'problem pistons' onto a bench! Wow! That's definitely what I would call a dirty piston! Part of me finds it hard to comprehend how pistons could get that bad when Audi Europe insists that drivers only use some of the best specified full synthetic oils that money can buy. The other thing this video confirms is that these dirty pistons suffer from stuck oil control rings.
I have long thought that the fundamental oil loss problem with these engines is a two-step process.
The first step happens when some clever-clever engineer crosses a bridge he should never cross and says 'it is normal for all engines to consume oil'. What I think this means is the engineer has compromised the ring pack to minimise ring friction in order to maximise fuel economy and power output. This obviously increases blow-by but the engineer relies on a well designed, but 'physical' oil separator to stop too much oil being routed back to the intake and burnt. However the oil separator will not knock out any oil that's truly in the vapour phase and this is what I believe can happen if you dump too much fuel in oil. When this unexpected oil hits the cold inlet system you get inlet valve fouling but this is the least of your problems. The real problem is that the oil burns (or more likely partially burns) and starts dumping deposits in the cylinder. These deposits progressively move down the side of the piston. Yes they foul the top and second grooves but the first and second rings constantly splay and retract as pressure changes. They also constantly rotate. This means they tend not to stick. It's when these deposits start to accumulate in the oil control ring that things truly go to pot. The ring tends to stick flush in its groove and you lose oil control. Once this happens you have oil rushing up through the second and first ring gaps directly into the cylinder and that's when oil consumption goes massively out of control.
Interesting stuff...
PS - sorry the video is in Flemish. Don't bother with YouTube's Auto-translate option as you just get gibberish (eg the ring is constipated!).
