IMHO 20wt does not cushion the puunding metal components take as as such intill something breaks used oil analysis will not show impending falure only wear rates.
bruce
bruce
Or are they smarter, those germans aren't stupid when it comes to engines.quote:
Originally posted by Geoff:
Gas in Europe can be $8/gallon yet xw-20 is rare. Why is this? Are they stupid or something?
the Jeep Lib disel doesn't get good MPG at all...look at the latest Consummer Report on itquote:
Originally posted by MNgopher:
Until you put a smaller turbo diesel in it to replace whatever gas engine is in there now. Hopefully the Liberty diesels being offered by Jeep will keep moving so the automakers get the hint that some of want this option.quote:
Originally posted by Raven18940:
Thin oils don't impress me, they're just a bandaid for a growing problem. You can't get away from the simple fact that the biggest factor in fuel economy is weight. No matter how slick the oil, how trick the engine, even if you could get the rolling resistance and drag to zero, if you have to move a 3 ton SUV you'll be hard pressed to beat 20 mpg.
My "ideal" truck would be a 1/2 ton with a six cylinder turbodiesel that delivers 24+ mpg freeway, hp like a small V8 and torque like a big V8. Ford almost did this in the F150's a few years back but backed out in a "cost savings" measure.![]()
Using a big V8 and a serious overdrive (0.50) enables the Corvette attain 28-ish MPG Highway while operating just above idle RPMs.quote:
Originally posted by Paranoil:
Using smaller, technically advanced engines in lightweight vehicles will provide much bigger fuel savings.
An even bigger savings would appear, if engine ECUs were programmed to limit acceleration and leave the 70 MPH speed limits alone. A car that accelerates at 0.25 Gs uses far far less gasoline than a vehicle that accelerates at 1 Gs. With electroninc throttles, the ECU can provide this limit.quote:
Originally posted by ex_MGB:
[QB] The biggest fuel savings is in lowering speeds. I think we're headed back to 55 mph speed limits. This will also keep vehicle wear down.
I, personally, will never buy another FWD car. I have driven many and never found one that has the chassis composure as a mid-engined rear-wheel drive car. Next in line are front-engined rear-drive cars, followed by rear-engined rear wheel drive cars, followed by 4WD cars, followed by FWD cars.quote:
The U.S. future is 4 cylinder engines, manual transmissions, full synthetics in the driveline, front wheel drive (less drive train loss), 20 wt engine oil and when the low sulfur diesel gets to market, more and more diesels.
Why even have a car at this point? driving is certainly no fun.quote:
mart highways and cars where cars and trucks can go autopilot and convoy/draft each other. Probably have to cull 99.9999% of the lawyers to get around liability lawsuits stifling technology innovation.
Many foreign cars have greater American content than cars from the Big 3! GM builds engines in Canada, and transmissions in Mexico and only assembles car in the states.quote:
ect U.S. jobs, the U.S. will mandate X percent of vehicle content must be domestic.
They said this in 1972, and for a while (1974-1985) it looked like a correct statement. We will see.....quote:
With the U.S. trade deficit, higher and higher oil prices will continue. Sooner or later the motoring public is going to throw in the towel on the gas guzzlers. If there's a major oil supply shock, it could be sooner.
I'll ignore the big brother and socialist implications and focus on the science.quote:
Originally posted by Mitch Alsup:
An even bigger savings would appear, if engine ECUs were programmed to limit acceleration and leave the 70 MPH speed limits alone. A car that accelerates at 0.25 Gs uses far far less gasoline than a vehicle that accelerates at 1 Gs. With electroninc throttles, the ECU can provide this limit....quote:
Smooth traffic flow is dependent upon everyone travelling approximately the same speed.quote:
Conversely, we could impliment MPG dependent speed limits. If you achiever 40 MPG of higher, there would be no speed limit, 30-40 gets to go 80 MPH, 25-30 gets to go 70 MPH, 20-25 gets to go 60, 15-20 gets to go 55, less than 15 gets limited to 50 MPH.
OK...then if you use the same engineering principles of the Corvette, just scale down the engine size (fewer cylinders?), vehicle weight with the same aerodynamics, just think of the MPG that could be achieved at 65-70 MPH.quote:
There is evidence to the contrary:quote:
A Corvette with its large 5.7 or 6.0 litre engine and a big overdrive transmission (6th gear = 0.50) can get 28-31 MPG at 65-70 MPH.
None of the competing sports cars with higher tech engines and similar performance get anywhere near this kind of fuel economy.
If you see failures from oil thickness/pressure, it will first be found in spun rod bearings IMHO. There will be plenty evidence for a seasoned engine builder to determine if the oil pressure alone was the culprit.quote:
bruce
Well, low throttle openings vs. high throttle openings make your statement true, but limiting acceleration rates (normally done by the driver by limiting throttle openings) most certainly results in better fuel economy. Slower accerelation is accomplished with fewer hp, which uses less fuel. Taking longer to reach your target velocity reduces consumption by reducing the amount of time you spend (and therefore the fuel you use) at target velocity. The most fuel efficient way you can drive is to make the engine produce precisely the amount of hp you need to maintain your target velocity and keep it there. From there, use the cycle efficiency and throttle to your best advantage. You'll take many miles to achieve a freeway speed, but you'll use the least amount of fuel in doing it.quote:
Originally posted by Jason Troxell:
Low throttle acceleration giving better mileage is a myth.
