The oils I'm interested in are Mobil 1 0w50, Mystik 5w50, and Kendall GT1 10-40 unless they make a 50.
The purpose of this exercise is related to the possible necessity of running a serious cam profile at rpms not friendly to hyd lifters. The 50 wt may allow that but at an increase in pumping losses. Knowing where specific oil vis is at a given operating temp compared to known temps will help in initial lubricant comparison, then choice .
i'm not sure what you need since there isn't alot of info but it seems to me that your looking for something that falls within a 50wt and yet flows as easy as possible(for less drag).
if you like mobil 1,they do make a 5w-50 that may serve you better than the one's you listed.
mobil 1 5w-50
SM/SL/SJ/CF
ACEA A3/B3 A3/B4
MB 229.3,229.1
[email protected]
[email protected]
sulfated ash-1.3
Ph-1000
Zn-1100
FP-228C
TBN-11.8
VI-184
HT/HS-4.3
i don't know if the ZDDP levels are what you may need though.
generaly speaking,most of the time,it can only be found at ford dealerships. they stock it and recommend it for the baddest mustang ford makes.(i forget the model name)
believe it or not,there are other oils that fall into the 50wt that flow even easier and yet have a stronger film strength and HT/HS.(read my sig,but that's a MC oil)
i'm not sure anybody here knows what you need.there's not enough info.
