An easy rear shock replacement has turned into a nightmare on this 2006 Altima. The shock mount bushing seized to the bolt, so when I turned the bolt the bushing was destroyed. Most vehicles that would be a non issue. But not this Nissan, the shock mount bushing is part of the knuckle assembly
The knuckle has 4 bushings total. A complicated labor intensive job to take on and off because of the design. Its a $500 car. I have about 1k in parts into it so I'm not ready to throw in the towel. Yet. Should I..
1) Replace with new knuckle for $200. (requires transfer of old rotted rotor splash shield, hub, ABS sensor, old ebrake hardware. )
2) Replace the 4 bushings for $58 + labor to press 4 bushings. What would the labor be if I removed and brought it somewhere? Its not simple to do with this knuckle. Needs a pro.
3) Take my chances on a used ebay knuckle partially loaded like this link The splash guard is in better shape. I don't have to deal with cutting the shock off the mount. But.. Are the bushings any good on the part I'm getting?
What would you do?
What would you do?
