I'll have to try this on my Bolens. The darn thing won't start worth a [censored], and won't continue running unless the choke is kept slightly closed. Since it acts as if it is geting too much air maybe the real problem is too little fuel.
agreed-went through 2 Homelite hand held leaf blowers-they each lasted almost exactly 2 years. Purchased An Echo 251 so now I'm hooked-I knew it was going to be a winner from the first pull of the engine-it was blowing leaves and the engine had not started yet.
I am now in the market for a replacement for the 15 year old McCullough trimmer-after 2 carb rebuilds it(and me) has had it
Went trimmer shopping today and looked at the Stihl FS 55R and Echo SRM 225. I think I'm going to pull the trigger on the Stihl- bigger engine, adjustable carb, and $20 less.
Originally Posted By: yeehaw1960
Solve your problems with the newer two stroke (lower end) machines. Buy the tool at Ebay (http://cgi.ebay.com/HOMELITE-CARB-ADJUST...=item1e58d6d6e8) and tweak that screw out 1/4 turn. Stuff runs great after that. I used to cut through the metal "barrier" around the screws with a dremel cutting disk. I would score the tops of the screw(s) with it at the same time. Then would turn the screw out 1/4 turn with a flat screw driver. It's the EPA's fault. They tie the hands of the manufacturer. The tools, which you couldn't get before unless you were an authorized service provider, are all over the internet for $10 or less. I use mine several times a week. Can usually send folks away with a smile on their face (and for free).
I recently bought a Homelite trimmer at Home Depot and it too ran poorly, but I adjusted the carb by using the Dremel to slot the mixture screws, but all I did was just slot them at the same time and slotted the outer tamper housing too. Just make a single slot all the was across both screws and the housing at the same time. It doesn't matter if you slot the tamper resistant casting around the outside because it has no function anyway.
