Fun With Dexter Axles/Brakes
Brentwood, MD
I was having a brake intermittently hang up on my travel trailer, I traced it down with a temp gun/back of palm temp check. After returning from the west coast, I took the drum off and was presented with a somewhat greasy mess. Thank you EZ-Lube. Someone on youtube had eluded to the corner of the brake lever getting hung up on the corner of the brake shoe. I was going to get a new lever (with a new bushing at the top pivot point), but etrailer.com had complete axle set assemblies (left and right) for $156.00. Couldn’t pass that up. So two brake assemblies and two axle seals, hopefully we’re back in business. I hand packed the wheel bearings before re-assembly then gently used the zerk to add some grease when the thing was re-assembled. I was especially glad to see that Dexter has now put a bevel on the part of the lever that was hanging up. Design improvements are always welcome. I guess Ill be doing the other axle before the next big trip. Befores and afters are below.
I'll often use the EZ-lube fittings to buy time between repacks, but I've always been concerned about the grease seal getting dislodged. I discovered that there is flat spot on the backing plate allowing just enough of a gap to get a peek at the seal with the drum installed. A bright flashlight is needed and an inspection mirror is helpful, but the wheel does need to be removed.
It's some nice peace of mind knowing that seal is still intact after pumping in all that grease.
I think thats the key. The bearings had plenty of dark, nasty grease in them, particularly the inner one. I’m not entirely sure how effective that system is in actually getting new grease into the bearings, the inner one especially. Maybe its possible that that grease turned icky over the last 7200 mile trip across the country and back. That trailer probably has 20k miles (or more) on it and I had never had the drums off before. Just adjusted shoes and ez-lubed the bearings. Whats the normal repack interval supposed to be? 15k?
My trailer doesn't get used enough for mileage to be an issue since they recommend annual repacks as well, which seems a bit excessive to me.
I guess that's another another advantage of the EZ-lube system, getting an idea of the condition of the grease as it is. I suppose if really nasty, watery or separated grease starts coming out it's time for a complete repack.
That's also why you're supposed to use an SL (single lip) seal, no?
I just use the factory Dexter seals, I haven't had one pop loose yet after two rounds with the EZ-lube fittings.
That is seriously frustrating. Are you returning?
Yes, they sent me a return label and they sent the correct calipers but they sat on the guy's desk for a few days and won't get here until Saturday. I was hoping to repair the boat today and get it on the water this weekend as my Wife is having a procedure on Monday that will keep her off the water for quite a while. Hopefully I can get a few years out of the aluminum versions.
Nothing more infuriating than stuff that’s in stock taking longer than same or next day to get shipped out!
What was the price difference between steel and aluminum?
I believe around $50 per caliper. $180 vs $130. Stainless would be best but most likely $500 for a caliper and I am not sure of a direct replacement.
