I was having a brake intermittently hang up on my travel trailer, I traced it down with a temp gun/back of palm temp check. After returning from the west coast, I took the drum off and was presented with a somewhat greasy mess. Thank you EZ-Lube. Someone on youtube had eluded to the corner of the brake lever getting hung up on the corner of the brake shoe. I was going to get a new lever (with a new bushing at the top pivot point), but etrailer.com had complete axle set assemblies (left and right) for $156.00. Couldn’t pass that up. So two brake assemblies and two axle seals, hopefully we’re back in business. I hand packed the wheel bearings before re-assembly then gently used the zerk to add some grease when the thing was re-assembled. I was especially glad to see that Dexter has now put a bevel on the part of the lever that was hanging up. Design improvements are always welcome. I guess Ill be doing the other axle before the next big trip. Befores and afters are below.
