My in-laws gave me their old tractor to dispose of on craigslist as they don't like wierdos showing up on their property, on the phone, etc. Wife says as long as it's over here let's order a dump truck full of gravel and fill in some low spots.
While the bucket and tractor seem to go together they couldn't be a worse match. Sorry the pictures are so bad at illustrating this but the bucket hangs waaay forward. The predictable result is most of the weight hanging on the front axle. It could REALLY use some power steering BTW.
Speaking of which, the tractor has no suspension and the front axle pivots in the middle so all four wheels are always on the ground. The only force keeping it from tipping over sideways is the solid rear axle with 10% or so weight on it! A previous rednecked "fix" for all this is a metal box on the rear full of old metal junk. I added a steering knuckle and four rotors I had laying around.
My property layout has me go down a short little hill then turn. Crest the hill as slow as I can and then sort of bomb down. Engine braking makes it do a "stoppie" then the wheels lose traction (being airborne and all) and it settles down, repeats.
Oddly a fellow could get used to driving that way!
Who wants a "kludge" story? Before moving gravel I was pushing my junk pile around, and may have hit a board with nail in it, flattening a tire. Get my rope plug kit, plug a couple holes, add air, find a couple more. Buy 30 rope plugs at walmart, figure I'm good. Add air and hear hissing when I move the valve stem. (Conveniently mounted INSIDE the wheel, I guess to protect it). Tire/wheel only comes off if a gooey greasy bearing retaining nut comes off.
Break the beads and my "valve stem" is a tube.
What happened was I pinched/poked the tube causing one air leak, and the existing tire had already been punctured so often a previous owner stuck a tube in! Called father-in-law to let him in on the joke, was news to him too.
for the 1st person to say I was overloaded. If it took 100, 200 trips back and forth to the pile anyone would push capacity.
Oh yeah and the barely guarded PTO belt is right by my foot! Watch those shoelaces!
