- Joined
- Aug 4, 2021
- Messages
- 1,371
My buddy has a Craftsman dyt 4000 lawn tractor he wasn't getting any spark. He bought a new coil from eBay or Amazon and installed it in the tractor and, the engine started right up, but when he put everything back together, the covers and everything it wouldn't start any more. so he tried another coil............. same thing ran for a while put the covers all back on now it won't start. (He did set the "air Gap" between the coil and the flywheel each time he installed the coils) I assumed we should have battery voltage to the wire that plugs on to the coil of a Craftsman DYT 4000 lawn tractor, but I must have this wrong, because I see the tab for the electrical plug provided keeps being referred to as a "Kill wire connection" So does this system need battery voltage to the coil to start and run, I am also going to have him test the old coil, and the two "new coils" he installed. Now unless the old coil was bad, and the two new coils are junk too, and failed to work after they were hot.
