From the book "Corvette C5" by Mike Mueller, "Out of the Car, two Gen III V-8s were run on dyno stands at full throttle for 50 hours with no complaints. Although that achievement met GM specifications, Gen III Chief Engineer Ed Koerner was not convinced; he raised the bar to 260 hours for two more LS1s, then 520 for a single engine. When torn down after its dizzying run, that latter V-8 reportedly looked like new inside."
That's 21 2/3 days at full throttle ! Pretty amazing.
From the book, "ALL CORVETTES ARE RED" by James Schefter.
Page 356, ". . . they all developed between three hundred thirty-eight and three hundred forty-five horsepower for every minute they were running."
and "Every one of those engines looked absolutely new when we tore them down,"
Referring to full throttle tests of 50 hours, 260 hours and 520 hours.
So, they were at full throttle and under load, AND to develop that horsepower they had to be close to redline.
IF the engine was run exactly at redline under "full throttle". Trying to keep this a real as possible, if you did that with the engine in a coupe that would be equivalent (in 5th gear) of 175mph. Doing that for 520 hours would equate to 91,000 miles, under maximum load and rpm.
How could the oil last that long?
