I have (2) Ilmor Viper V-10 engines, (625 hp@) and they recommend to use Mobil 1 15w50. Nothing was said about "Extended Use" or the new Mobil 1 5w50 oil. These are the same basic motors as the Dodge Viper, just souped up and no emissions and where I am we have 93 octane.
What might be a better oil than this? I know M-1 recently came back out with the standard Mobil 1 5w50 oil that says "It's New"! What's the real difference between the "Extended" and the new Mobil 1 5w50 new oil?
I run these motors a lot between 4,000 & 5,500 rpms and I do watch the oil temps and I use Perolater "Pure One" oil filters and I change the oil every 25 hours.
What is a better oil for these conditions & use? The Boat does not stay in the water and it has a closed cooling system and the top temps run about 160-165 degrees The Top oil temps run at about 190 degrees at full throttle runs and at cruising I see about 150 to 160 degrees in oil temps.
I've run Redline Oil before, but being on the east coast the shipping kills me. I need something I can buy every where that will give me the best protection for the $$$
Give me your real thoughts on this!
Thanks,
Gary SC
Thanks,
Gary SC
