full synthetic high mileage
Originally Posted By: irocurpony
Is valvoline maxlife full synthetic and Mobil 1 High Mileage the only High Mileage full syntheic High Mileage oils?
As far as I know. I would think if you add Lubro Moly oil saver to any oil you will make your own High Mileage oil.
I dont know of any others at least where I live but they seem to be really good I started using valvoline maxlife full synthetic this year but both should be top of the line love the base oils and add pack
Valvoline MaxLife in the red bottle is a syn blend.
MaxLife Synthetic is in the silver bottle, and is harder to find. Our Meijer stores in Michigan carry it.
I have used Mobil 1 High Mileage, and think it's really good stuff.
I've haven't used any of the MaxLife oils.
Yes as far as I know. And if not they are the only ones available readily. There isnt a whole lot of demand for a high mileage synthetic outside of bitog and what not. Mostly people just do there own oil to save money afaik or well most of the people who would wonder into the oil department at walmart.
But I have been using the Mobil 1 High Mileage oil in my car for almost two OCI's now and its deffinately cut way back on the consumption. I cant really give it a fair review because i have multiple leaks on my car due to an overheat and i believe the rear main seal is leaking but other than the small leaks its really cut back on oil consumption. if i had to ballpark it i would have to say i went from about 1 quart ever 2k miles to about 1/2quart ever 3k miles.
Still you cant go wrong with either. im switching over to valvo hm syn next oil change because my local miejer carys it and if I can avoid a trip to walmart i do. its always a huge fiasco getting into walmart for me and usually ends with alot of frustration and anger.
Good luck
Sean Scott
I think ill take your advice i have 6 quarts of 10w30 mobil special and a 300ml of oil saver ill try. changing my oil next week i think 300ml isnt enough for 6 quarts though.
