Originally Posted By: Jimmy9190
I had ping under a light throttle in my Dakota. It's a common problem on some of the Mopar Magnum engines. About 5 years ago I fixed it, by using a different degree thermostat and a colder spark plug.
This past spring, I did tune-up on my truck and this time went with the factory heat range spark plug. I thought the ping might come back on a stock heat range plug, but so far I still have no ping at all, under any condition.
I have been adding MMO to my gas at every fill-up for about 2 years now. I have also added it to my oil a few times, mostly during the cooler months. It doesn't really get "cold" here in Florida, but we do have a few days in January and February with the high temps around 45 or 50.
I have a theory, no I can't prove it so please don't ask for proof, but I have an idea that the constant use of MMO and an occasional dose of Red Line or Regane has cleaned the carbon from my pistons and the use MMO in my fuel on every tank has kept the pistons and cylinders clean so no carbon has re-formed, therefore I have no ping now on a stock plug. I bet I still would have no ping even if I went back to a stock thermostat too.
I have no way to prove my theory. I admit it. Some people here always demand scientific evidentiary proof whenever one of us posts that we got a good result from the use of MMO, otherwise the improvement or gains may as well not have happened at all. I have no proof other than the fact I have no ping and am using a stock heat NGK plug.
This may not help the OP. I realize that a 6 cylinder Dodge engine is very different from an 8 cylinder Ford, and it could have taken a year or a little longer for the MMO to clean my pistons and cylinders. I do not think an initial use of MMO will solve the OP's ping problem. Over time the use of MMO could help him but it seems to me from reading his post that he wants to find a cure now.
I have no way to know how long it took for MMO to help with my carbon/ping problem. I do believe MMO is the reason I have no ping now though. My truck has almost 147K on it now. It runs great, no ping at all and has a nice smooth even idle. I attribute that to my own regular and often ahead-of-schedule maintenance and the use of MMO in every tank.
Hey Jimmy, don't let them scare you off, if the product worked for you post your comments and findings. If it failed shout it out too. This information can benefit someone else who is willing to try something out of the box because the data isn't available, or they've read enough credible testimony to try it for themselves. This is just another way to learn, and share.
