I bought a new Hyundai Accent in June 2011. It was one of the first of the new 2012 body styles to be imported. It has the direct injection engine.
The car has always had Top Tier gasoline burnt in it.
At about 25,000 miles the car developed occasional part throttle ping when climbing hills. Now, with almost 60,000 on the clock, the car pings quite a lot and frequently when under even a mild load. It seems to be getting worse.
I can only assume the problem is that there are deposits forming on the piston crown and combustion chamber that have increased the already high mechanical compression ratio of 11:1 even further and the carbon deposits have a slight glow-plug effect, and that is what is causing this problem. Top Tier gas is SUPPOSED to reduce these deposits and prevent them from forming significantly.
So is Top Tier a bunch of lies? Are the gas stations I'm using cheating and secretly buying fuel from their suppliers that doesn't have the Top Tier additive package put into the delivery truck?
The car didn't ping AT ALL for the first 20,000mi. I'm using Shell and Exxon gas almost exclusively, and when that's not available I drive out of the way to get another top tier brand. I'm using Quaker State Ultimate Durability Synthetic motor oil. Could the pinging problem have something to do with the direct injection, or is there some other explanation.
Any ideas?
I always use 87 octane, as this is an economy car and that's the reason I bought it. I wanted the highest MPG car that used the cheapest fuel, and the owner's manual states that it will run on any gasoline of 87 octane or higher. I tried running some 93 octane in it to see if it helped, but it still pinged, although maybe not quite as bad.
What gives?
Any ideas?
What gives?
