fuel quality and ethanol
UK
since it first introduction and now creeping in in higher concentration like a cancer, I have been wondering is it also allowing petrol producers to use lower & cheaper octane fuel and bump it up by adding ethanol while charging the customer the same or higher price🤔
Since EtOH has a higher octane rating than gasoline, and fuel is sold at a specific octane rating, then yes if you increase the concentration of the ethanol you would use a base with a lower octane rating.
Or keep the base gasoline the same but use less per gallon. If ethanol wasn't so highly subsidized, it wouldn't be less expensive.
In this Engineering Explained video, Jason goes through the switch to ethanol in gasoline and why he's no longer a believer in the benefit of using it. It's a few years old, but I don't remember seeing him post a rebuttal to his own video, which he will do when he thinks appropriate.
There are only two grades of gasoline, but the base octane can vary a bit. All other grades are blended from those two, with ethanol considered in the final product.
I think it's a lot more than that. I've heard it described as "buckets" of this or that and then the refinery blends them together to meet the requirements for finished fuel. But there are certainly industry standards. The most commonly traded commodity fuel in the US is RBOB, meant to be blended with 10% fuel ethanol in order to meet the 87 AKI requirement for regular unleaded in most of the United States.
The original post was obviously meant to be inflammatory. The quality of fuel isn't necessarily better or worse with ethanol, MTBE, or whatever. But we're dealing with an industry where currently ethanol is the cheapest and most effective way to increase anti-knock properties. There are people with flex-fuel vehicles who go out of their way to get E85 just on the basis of performance gains (at the expense of MPG).
After 35 years in the industry, I've never seen a "bucket" of anything being added to gasoline. Now, some niche markets, like racing fuel from specific sources do exist, but these are not normally "pipelined" commodities. And California is a whole other story, which is why refineries are closing there.
Unless those buckets are REALLY big, like thousands of barrels, it wouldn't make economic sense.
Blending racks are a thing, as well as computerized control at the terminal, that's just the way it's done.
Let's hope MTBE is LONG gone btw. A friend of mine would haul tanker loads of that stuff out in Colorado years ago. Passed out a few time from the fumes (yes, while driving) and the loads would always come up short. Come to find out it was actually escaping through the solid aluminum shell of the tank truck. No leaks!
Except this happened 20 -25 years ago. Two grades of gasoline, 84 octane and 91 octane. blending AND ethanol does the rest.
Unless the refiners move to 82/83 octane for RBOB and 89/90 for premium, with 15% ethanol, I don't see it making much sense.
Octane does cost money at the refinery end.
I meant that the refinery distills different streams of fuel that might be 85/87/89/91/93/95 AKI. I remember seeing quotes of an article from Sport Compact Car magazine about why California was turning to 91 AKI for premium unleaded when it was traditionally 92. I remember the word bucket, but it was more about blending stuff and placing it in a "bucket".
This is one version of the article as quoted:
You see, when crude oil is refined into gasoline, the refinery doesn't have all that much control over what comes out. Crude oil is full of all kinds of stuff, and a refinery simply separates it, sorting all the iso-this and hepta-that in order of density. The really heavy stuff, like tar, is near the bottom, while the really light stuff, like butane, is near the top.​
Somewhere in the upper ranges of the stack are the components of gasoline. There are between 10 and 15 different blend stocks, each with a different octane rating, which are mixed together to make gasoline.​
The crude oil being used and little else determine the amount of each blend stock available for mixing. Generally, if you just dump all the blend stocks into a bucket, you end up with something around 88 or 89 octane. If you're selective and only mix the good stuff, you can make 92, 93 or even 95 octane. But once you take out the good stuff, you're left with crap--something like 85 octane. Then you have to leave enough good stuff in the bucket to bring this pee-water up to at least 87 octane. This limits the amount of 95-octane gas you can make. If you make 93-octane premium instead, you use up less of the high-octane stocks, allowing you to make a higher proportion of premium fuel.​
So higher octane cost more to produce at the refinery.
Here 95RON is the regular fuel rating.
Can you add ethanol to bring this up to 97 or 98 or 99 RON and would it be more cost effective than producing a higher RON from scratch?
MAybe someone with deeper knowledge in this area can shine a light on this.
PS IMO ethanol was & is purely a political move in the wrong direction
There are some chemical processes (hydrocracking) that boost the overall octane rating of the fuel. That has costs. But I've heard it can actually increase the amount of usable gasoline and diesel fuels. But for the most part, fuels are produced through fractional distillation. They're just trying to separate out the components of the crude oil by boiling point, which I believe correlates somewhat with molecular weight.
I wouldn't necessarily say it costs more to produce. It's just pulled out from crude oil. It's more a matter of how much the customer is willing to pay based on the utility. It's certainly possible to produce more higher octane rated fuel from existing fuels, but what do you do with the stuff that's left over and can't be used as motor fuel for modern cars?
As far as ethanol goes, there really needs to be some sort of oxygenate to increase octane rating. MTBE is still used in some places. But ethanol is possibly the cheapest octane booster available. It's something that would still be used regardless of mandates.
The industry standard for gasoline is 87. But getting gasoline's octane rating up to that standard costs money. It means more refining of the petroleum, or using high-octane compounds in your gasoline formula, such as — you guessed it — ethanol. So gasoline companies aren't using ethanol for its energy — they're buying it for its high octane rating.​
There are other compounds that you can add to boost octane levels, but many, like alkylate or iso-octane, are generally more expensive than ethanol. Another additive that is widely used globally, called MTBE, has such a bad reputation for polluting the environment that many states have passed regulations that make it difficult to use.​
The ability to add ethanol and reduce the RON of the base fuel is limited in Europe. There's a very tight density spec that needs to be met, and if you reduce the RON, you end up with less dense fuel, while ethanol itself is very much les dense already.
It's rare for fuel in europe to have the max allowed amount of ethanol in it anyway. From what I've seen 2-3% is common, in both E5 and E10.
Yes it is highly subsidized, but its generally not cheaper for the refiner - because the refiner would be Exxon, Chevron, etc and there base crude per gallon of gas would be much cheaper usually. The EPA assigns how much Ethanol each refinery must blend in a year. How this is actually controlled is beyond me because the ethanol is blended in at the terminals, not refinery. Its really quite perplexing to me.
MTBE, or whatever.
I am pretty sure no US refinery uses this anymore or has in a long time. I have heard mixed reports that some places in Canada still might - which I would find odd but maybe someone here knows.
I remember going through a 1989 Integra owners manual. It specified a max of 15% MTBE, 10% ethanol, or 5% methanol. But the caveat was that methanol had to include corrosion inhibitors. I seem to recall that methanol was rarely available and phased out quickly.
As far MTBE goes, it's still listed by the EPA as a fuel additive available from several companies.
https://www3.epa.gov/otaq/fuels1/ffars/web-addt.htm
Methyl Tertiary Butyl Ether (MTBE)Noble Americas Corporation
Methyl Tertiary Butyl Ether -MTBE (CITGO Refining)CITGO Refining & Chemicals, Inc.
Methyl Tertiary Butyl Ether -MTBE (EGP)EOTT Energy LLC
Methyl Tertiary Butyl Ether -MTBE (Star)Star Enterprise
Methyl Tertiary Butyl Ether -MTBE (Sun Refining)Sunoco, Inc.
Methyl Tertiary Butyl Ether -MTBE (Texas Petrochemicals)Texas Petrochemicals Corporation
Methyl Tertiary-Butyl Ether (MTBE)Equistar Chemicals, LP
MTBEBP Products North America, Inc.
MTBEVitol Inc.
MTBE (American Agip)ENI TRADING & SHIPPING INC.
MTBE (Chevron)Chevron Products Company
MTBE (CITGO Petroleum)CITGO Petroleum Corporation
MTBE Blending Component (ARCO)Lyondell Chemical
MTBEVitol Inc.
"In 2005, Congress passed the Energy Policy Act that removed the oxygenate requirement for reformulated gasoline (RFG). At the same time, Congress also instituted a renewable fuel standard. In response, refiners made a wholesale switch removing MTBE and blending fuel with ethanol. According to EPA’s RFG Survey Data, MTBE has not been used in significant quantities in RFG areas since 2005. A similar decrease in MTBE use has also been observed in conventional gasoline areas." -- https://archive.epa.gov/mtbe/web/html/faq.html
Its still exported. Perhaps also used in someting other than gasoline - that I don't know? https://www.argusmedia.com/en/news-...49-us-mtbe-exports-surge-to-7-year-high-in-1h
There's still bound to be a demand for oxygenates simply as an octane booster. What else has a blending octane of over 104 AKI and actually costs less than gasoline?
The thing about MTBE is that it's not particularly toxic compared to gasoline. The problem was that if it got into water supplies (where it was also water soluble unlike gasoline), it would give off an objectionable odor/taste.
The water supply is exactly why its not used. It was never banned but the refiners figured out they would be sued into oblivion if Joe gas station leaked it into the cities water supply. Joe claims bankruptcy - who gets sued. It was about oil company survival in a litigious society.
If it has uses outside retail gasoline I believe you. However everything I have read from the EPA and oil industry reports is no refiner in the USA uses it in gasoline. Could be in imported product but most of those go to the West Coast, and all the CARB states banned it outright years ago so that eliminates the majority of that. Avgas doesn't use it.
So maybe someone, somewhere still uses it in gas they import from somewhere - never say never. If you know where it is used that would be interesting to me - just to know. But I am pretty certain your not going to get it from a retail pump handle in the USA.
I remember seeing some SDS for racing fuel that said it contained MTBE. But it was kind of old so it could have been an older description. If it's only sold in a big can, that might be different than stored in underground tanks.
There were several things the oil industry liked about MTBE. One was that they could make it themselves. It could also be transported by traditional pipelines, and finished fuel could be transported by pipeline. I believe fuel ethanol has to be added at the fuel depot and needs to be trucked in.
