Hi,
I use 75 percent E5 gasoline (95Ron/roz) 15 percent toluene and 10 percent ethanol as fuel in my car. (And also 30ml of TCW3 per 18 liters of total fuel) - This is done for octane enhancement purposes.
Today I've noticed that although TCW3 seems to happily dissolve in Toluene, it's not dissolving in ethanol and TCW3 droplets seem visible, the droplets seem to mix when ethanol with added tcw3 is vigorously shaked but reappear after some while.
1) Did anyone else run into the same problem?
2) Will this cause sudden leaning (afr) in individual cylinders or will the 75 percent gasoline easily dissolve droplets in the fuel tank if there are any?
3) Should I or should I not use TCW3 when using ethanol?
Info: Car is direct injected and turbocharged.
Many thanks in advance.
