Hey guys,
I had emailed Shell with some questions regarding the ethanol content throughout the grades, along with labeling the use of ethanol if required through them (versus the state).
Here is the response I had received:
Thank you for bringing your concerns to our attention. We forwarded your inquiry to our fuel specialist and here are the answers to your questions.
1) All Shell gasoline is Top Tier certified, whether it is gasoline with no ethanol or gasoline with up to 10% ethanol.
2) Yes, all Shell stations are required to have a label on the pumps if the gasoline contains ethanol.
3) Not usually, it is normally 10% in all grades. However, in some markets that have a higher demand for gasoline for marine applications, a station might offer a premium without ethanol. This is generally hard to do from a terminal blending and supply perspective.
So just in case you were wondering some of the same questions... Appreciate the customer service from Shell!
