Originally Posted By: speer
nobody has a clue thats good thought it was just me that dont understand this fuel injected computerized stuff
We're kind of joining this repair in progress. What was your initial problem, what lead you do change the regulator, and what would you consider a happy ending? Where the regulator sits, could there be interference if the motor were in, say, a mustang with a different intake? Maybe the new part is more universal than the one that came on your year truck.
The lines leading to it are 1) pressure on the fuel rail/injector side, 2) "no" (some) pressure going back to the tank, and 3) vacuum. Gizmo acts as a restrictor keeping pressure up at the injectors, and all the extra fuel going round n round keeps stuff cool and not vaporlocky.
As for flooding, you might want to check your coolant temp sensor if the relearn doesn't fix it. If the truck thinks it's -40'F it's going to skip a lot of the other sensors until it sees itself warming up.
