Thanks for the replies, I think I'm leaning towards a new carb or carb rebuild. I went out and looked and I can't find a name on the carb at all. It's not the stock one but not sure what it is, it's a two barrel. I did notice that when I pumped it by hand a couple times, there was a little gas leaking out of the throttle shaft. It wasn't the side the linkage is on, but where the shaft passes through the opposite side. There's definitely something not right with this carb. I don't think I would be able to rebuild it good enough, as carbs aren't something I've worked on very much. Probably start looking at some new ones.
