Have a 2008 Honda Odyssey, it threw p0455 which is massive egr/gas leak. Replaced the gas cap, fixed the issue however it dumped a fair amount of fuel in the oil (pushed the oil level just over max when it was below previously.) Current fill is Pennzoil Platinum 5w-20 with 2k miles on it.
Questions:
1) Should I dump it now
2) If I do dump it should I go with a normal oil change or should I do a short cycle with a "cleaning" oil before going back to my intended oils.
Since it has VCM it loses about a quart every 5k miles, I thought about running Pennzoil Platinum 5w30 HM or AMSOIL Signature Series 5w20.
Open to suggestions.
Questions:
