I always thought that the front pads will wear out much faster than the rear brake pads. Most of the cars my family owned were disc up front and drum brake in the rear. Seems like the rear brakes will last at least 2-3 front brake pad changes. My 02 VW Jetta is the only car in my fleet with 4 wheel disc.
I recently changed the front brake pads on my VW Jetta at 60,000 miles (original pads). It does have a front wear sensor and was getting close to cutting the sensor. I replaced it with a set of Wagner ThermoQuiet. While inspecting the rear brakes I noticed it was somewhat close to the amount of wear of the front. I'll replace the rear as well so I ordered at set of Bendix CT-3 pads for the rear. Just wondering if its normal to have even wear for front and rear? Or do drum brakes for the rear generally last longer? Thanks.
