Ok, so there are a number of different types of brake pads, ie: metallic, carbon, semi-metallic, ceramic, performance friction, etc, etc. Each pad has a unique set of characteristics.
Is one risking excessive break wear or braking system imbalance if they, for example, use cheap pads on the rear disc brakes, and ceramics on the fronts? Does anyone recommend maintaining the same 'technology' of brake pad on both the front and rear brakes, to promote overall balanced system operation?
I ask because I've converted my fronts to Raybestos ceramics, but I'm not really sure what pads are on my rear brakes and they still have a fair distance to go before they will require replacement. Anyone have any advice whether it is safe to mix and match different technologies on front and rear brake pads?
