JHZR2
Staff member
Hello,
I have a fluke 179, which I use for various projects.
Today, I think that I had the leads set up for a 400mA test configuration (max, IIRC), and set the meter to volts and tried to find battery voltage. Didnt work (duh!), and so I fixed which thing the leads were attached to - worked fine and still does.
However, after that, I tried to do a test of current later on, and I cannot get a DC current with my leads set up under the 400mA setting and 'mA' on the selector dial.
If I use the 10A fused connection and set the dial to 'A', then it works, and I get a reading.
I took the meter apart, and pulled the fuse for the low current test circuit. I used the ohmmeter to test for continuity, and the fuse checked out... Id think that if I had blown the fuse, that it would check out as infinite resistance.
Also, it should be noted that when doing loose checks of current draw on my battery, I usually see a small spark at hookup. The size depends on how careful and direct I am. With the leads and setting on 10A, I see that small spark. With the leads on the 400mA setting, I dont see a spark. So it seems that there is an issue with my low current channel. But what? If the fuse checks out, then what next?
Did I kill the channel somehow?
Thanks,
JMH
Thanks,
JMH
