Originally Posted By: bruce381
Originally Posted By: MolaKule
Remember the three stages of lubrication protection (in simple terms):
1. Fluid film - elastohydrodynamic lubrication - friction reduction and cooling by the lubricating film; components float on a thin film or wedge of oil.
2. friction modification - in this case it is friction reduction; provides some minor AW protection as well.
3. AW/EP for boundary lubrication when the fluid film is ruptured.
I would put EHL as a 4th since it is not "liquid" film but solid film
bruce
Bruce, is that not the same as #1? My understanding is that plastic films are only formed under boundary conditions between 2 asperities near contact.
Kinda splittng Hairs EHD lubrication occurs mostly in gear teeth and roller bearing ans at the high loads the oil turns "solid" and to me is NOT that same as saying "oil film or oil wedge"
bruce
Ahhh I see. I (and maybe Molakule) was confusing normal hydrodynamic regimes with EHD.
Quote:
Engine bearings and the piston mostly operate in the "hydrodynamic lubrication" region, where a thick film separates the moving metal surfaces so that there is no chance of them coming into contact. When the pistons are momentarily stationary, however, the layer of oil covering them can be similar in thickness to the surface roughness of the components. In this "mixed lubrication" region, the metal surfaces intermittently come into direct contact. If the thickness of the oil film is much smaller than the surface roughness then the metal surfaces rub together repeatedly - this is known as "boundary lubrication". Contact between the cams and the tappets in the valve train span the mixed and boundary regions.
The final type of lubrication - elastohydrodynamic lubrication - occurs under high loads and is commonly encountered with hydrocarbon-based oils. Here the pressure developed in the lubricant is sufficiently high to elastically deform the metal surfaces either side of the oil film. This happens because the viscosity of these fluids increases significantly as the pressure rises. The valves and the piston rings occasionally operate in this region.
Lubricants are also used in other important components in a vehicle, including the gearbox. This is a challenging environment where pressures routinely exceed 109 Pa and the gears operate in the elastohydrodynamic-lubrication regime.
http://physicsworld.com/cws/article/print/5020
