Fresh Oil = Quiet
I see a small flaw here, which is likely easily fixable. No two cars are fully identical: usage, patterns, weather, etc... When we notice the sound difference - it's always the same vehicle, just at different times and old/new oil in the crankcase.
I also mentioned (either here or on other similar threads) that I can notice by valvetrain chatter which engine is low on oil. That happens on the vehicles of friends and family that I maintain. Since I'm the one servicing them - I know how quiet those engines are with fresh oil at full capacity. So when my God given hearing sensors go off - it often ends up being that the vehicle in question is closer to the end of its OCI, or is currently low on oil.
I guess I should also note that I come from a musical family, we all sing in choir or solo or groups, and all have hearing that is trained to be extremely sensitive to changes in tone, or changes to a single instrument in the orchestra, and so on. So when the engine orchestra is slightly off note - I spot it quick, but to an average DIYer it may not be as obvious.
There is no need for two vehicles.
Start the vehicle up cold, measure the db level, shut it off immediately after so it doesn’t warm up. Let it set for a little while. Do a cold drain oil change. Then do a cold start on the new oil and measure the db level.
Post data here then listen to the oil nerds tell you how your method was flawed or you didn’t use properly calibrate instruments or you didn’t set up a control test. Then hate yourself for even doing it. And I wonder why you’re wasting your life.
I explained in earlier post here (#44) why Decibel meter is useless in this test. 🤷‍♂️
There it is…
On that topic... Which one do you think ran quieter?
This 2008 Pontiac Vibe with 90k miles total and ~1000 miles into this OCI?
Or this 2000 Lexus GS300 with 365k miles total and ~3500 miles into this OCI?
Both had Mobil1 0W-40 at the time of pictures, with ~25% MMO. I was a heavy MMO user at the time of owning these two...
Sound/vibration data needed. You do 5K changes with HPL on a 14 yo NA Accord with 270K miles? Why?
It's not needed. I still hear the engine running nice and quiet. Once the oil gets 3-4k miles on it, the engine will begin to get noisy again.
I do 5K mile OCI's because at 160k miles, I had to replace the timing chain and everything that touches the timing chain because of long OCI's (10-11k mile OCI's) running M1 oil. I don't want to go through that again.
I run HPL SuperCar through my car now to help dissolve and remove all the varnish that I saw in the engine the last time it was taken apart (I had to replace the exhaust cam).
https://bobistheoilguy.com/forums/threads/2010-accord-pitted-cam-lobe-pics.367037/
I don't mind splurging a little bit on this car. We have a long history together and my son and I spent 5 years in it traveling all over the US chasing BMX Nationals.
I can't say without having heard it and measuring it with lab-grade sound equipment in a sound-dampened room.
Some people are more hearing-sensitive than others.
Some people are more seeing-sensitive than others.
Some people are more feeling-sensitive than others.
Some people are more emotionally-sensitive than others.
Some people are more taste-sensitive than others.
I could go on & on..... plug in 8-10 more...... even include ethnic, racial and sexual into this equation.
My Tacoma doesn’t have the pronounced taco tick that Tacoma owner’s experience. I’run Amsoil and biotech for a while now.
You guys are funny as heck.
I didn't mean to start anything. But I can hear my valve train later in an OCI and it's quiet at the beginning. That's all I was saying. Carry on.
It's all good, many report the same but this is BITOG and WE WILL argue about the minutiae! Plus, a laugh/memes are good for you sometimes.
Was that the first oil change on that Vibe?
