Originally Posted By: mva
Fram filters are fine - if you can get past the cardboard end cap issue. Keep in mind that the oil pressure pushing the oil through the media is also pushing the end caps tightly against the media. At 10 psi there would be about 60 lbs of force pushing on each end cap given a 3" diameter.
Sounds like a good reason to have metal end caps.
