Fram XG8A C&P
BC1
GA
Came off 2004 Jeep GC 4.7 260k 5k on filter. 6 qts Mobil 0w-40+500ml rislone. Same filter and oil mix when back in. I was surprised by how much stuff was in the pleats with nothing in the can. Not sure if the oil or the rislone is doing the cleaning.
1000000493-webp.269070
View attachment 269066View attachment 269067View attachment 269068View attachment 269069
Looks good. Thank You
I bought it about a year ago after it had been sitting for a few years for $500. Engine was ticking so I had the valve covers, timing cover and oil pan off swapping the timing set. One of the tensioners came apart(hence the oil pan removal to check the pickup). It was clean inside. I did two 3000 runs on total 5w-40 and both filters were spotless before this. That is why I was surprised by this one.
Date code 109th day of 2023. Wire backed OG Ultra in design transition stage. No louvers yet, leaf spring pretty ruffles free and leaf spring seal on the end cap is gone.
