FRAM Ultra XG3600 Cut Open - 2000 miles - HPL EC30
Its been about over 2600 miles on the current oil life with 3.8 quarts of Valvoline Full Synthetic High Mileage MaxLife 5w-30 + 0.8 quarts of HPL Engine Cleaner 30 + 11oz of BG MOA. The 2012 Yaris which has most of its miles since owned on the highway did had a 20 minute BG EPR flush done prior to this go give the car a head start to transition the vehicle to HPL oils in the next coming oil drain. One observation I do want to point out is how unusually dark the oil came out of the filter during removal. Normally the oil comes out fairly semi-clear amber at 5000 miles so it seems there is some light post cleaning going on with HPL EC and held it in suspension. The vehicle current mileage is at 140,390 at the time of this thread posted.
The filter is the newer generation of Fram Ultra non-wire backed blend media. Not very interesting to look at, everything held up together nicely.
A little fuzz like appearance on the element, and Pleats are fairly tough to flex with fingers comparable to the Toyota D3 filter I pulled out earlier to observe any debris captured. Counted 53+1 pleats including the metal seam in a total of 54.
Louvers are well opened. Dome can snapshot show very little going on.
Its quite a long filter, almost 4 inches tall compared to the 3-1/8" tall YZZD3 filter element.
As you can see, the filter element doesn't appear to be broken in yet just like YZZD3 which was on the vehicle shortly for 680 miles.
Wrapped it in Scotts shop absorbent towels to leave it wicking dry for a few days.
The filter was replaced with a Fram Titanium FS3600 (pink wire backed media) and topped off with remaining jug of Valvoline oil.
With a small, high revving engine, ala Yaris, it is good that you are getting on top of keeping it sparkling clean.
Make it nothing but HPL with extended OCI moving forward FTW.
There are many top tier flavors to select from.
The 1NZ-FE is not a "dirty" engine, I posted pictures of mine at nearly 300,000 and it's very clean inside. It's nothing like my 1MZ-FE.
The new Ultras have louvered center tubes? Fram website shows the center tube as having holes.
Been a long time since I updated this, over 2 weeks of sitting with 2 changes of shop absorbent towels, finally got around to cutting the pleats. As expected, the engine is running clean, hardly anything other than the media held up very well. There were a few black dots of carbon material that disintegrated into powder after a slight press with a finger.
You can see the thin layer of fuzzy filtering material on the cross section pics of the media cut. A knife scrapped off some of it as well when inspecting, theres a bit of depth in them, just not as much depth compared to the old pink media. I measured the endcap to endcap length and its a little over 3-15/16" in length or 4 inches nominal. Thats roughly double the filtering height of a YZZN1 media which is 1-15/16" in height in comparison.
20231216_135802.jpg20231216_140020.jpg20231216_135958.jpg20231216_135852.jpg20231216_135827.jpg20231216_140937.jpg20231216_140746.jpg20231216_140723.jpg20231216_140242.jpg20231216_140233.jpg
