Originally Posted by slacktide_bitog
Originally Posted by bullwinkle
Only downside of the "leaf" is it tends to straighten out if the filter is dropped hard, which usually dents the filter anyway. Leaf spring and can weakness are the Ultra's weaknesses, if they could only put on a Distance Plus can, and Wix coil spring and bypass, then it would be pretty close to perfect!
The problem with Wix's setup is that it takes up too much space in the can. The problem is especially damaging in the 57356, resulting in a very small media cartridge, even for its size. For that application, the Fram 7317 is much better due to having more media in the same size can.
I agree-I personally haven't had any loose element/collapsed leaf spring issues, even on eBay 6-packs that were obviously returns in messed up boxes, not packed well, with dome dents-but I wish that Fram could help out a little bit on the can thickness on the Ultra. I've been removing a few that got hit by gravel & road debris from our "wonderful" 3rd World looking roads here, before they normally would have needed to be replaced, because I was worried about can failure on the Ultras.
