I opened up a Supertech, AC Delco, Fram and Carquest (Wix) filter for my 02 Saturn SL2. The Supertech, STP, AC Delco are all identical Champion E core filters in every way. They have exact same media, duel anti-drainback and bypass valve etc. I also noticed none have metal end caps but a end cap similiar to the Fram. For some reason the Fram did not have the cardboard glued on end caps but some type of filter media end cap matching the E-core filters. Last time I cut open a Fram it was easy to tell it was some type of cardboard/fiberboard sloppilly glued on. Anyone know whats up? Alot of people swear by the E-core filters, any advantage to the metal end caps found in the Purolator/WIX made products? Any advantage to the WIX actual coil spring vs the flimsy looking stamped metal spring (ie filter hold down element or spring)? The spring is supposed to keep the right amount of pressure on the filter cartridge to keep it seeled against the anti-drain back valve. Also how tight does everyone put on their filter? I feel if you go more than 3/4 to 1 turn after the filter contacts the base somehow you distort things and effect the inner workings of the filter.
