dnewton3
Staff member
Originally Posted By: goodtimes
Originally Posted By: dnewton3
Originally Posted By: ZraHamilton
I am wondering if the extreme efficiency of the fram ultra (99% @ 20, 94% @ 10, and I even heard someone say 80% @ 5 microns) would create a large pressure differential and cause it to bypass often. The bypass valve is extremely flimsy and easy to push because of the weak spring and plastic valve. This seems like the biggest weakness of the ultra. If it bypasses often, that 99%+ becomes 0% lol.
Also, wouldn't the Wix XP have the lowest pressure differential of nearly any filter? (with fiberglass media and 50% @ 20 micron efficiency). If so, you get the filtering efficiency of many OEM filters, but with excellent flow, and the toughest construction.
1) oil filters RARELY go into bypass; read Jim Allen's trials please
2) oil filters flow well more than the oil pumps put out; show me any data to prove otherwise
3) the Wix/NG and Wix XP are rated at same flow volumes for equivalent applications; go check their website
4) what makes you think the BP valve is "extremely flimsy and easy to push because of the weak spring and plastic valve" (As opposed to the bazillions of others just like it in other brands?) What makes the plastic "flimsy" and the spring "weak"?
This thread is just a new version of the old (unfounded) complaint regarding the PureOne filters being "too restrictive"; a totally uneducated view that if it's efficient, it must also be too restrictive because one's brain cannot conceive that the product can be both efficient and flow well
Where do some of you get these ridiculous ideas, anyway?
It's not a ridiculous notion at all that small hole area restricts more than larger. A water faucet has such controls. The manufacturer has to be trusted. Fram shows testing, Mann puts flow data in their brochure. What's ridiculous is to assume someone says "is the Ultra too restrictive?" and say "don't say it is too restrictive." They are asking a question, not saying it isn't true. The title of the thread is a question, not a statement.
Again - more of an argument not well reasoned ...
Knowing the size of the holes is only HALF the equation. Did it ever occur to anyone that a larger quantity of smaller holes will assure the same net flow result? You know, several smaller 1/2" pipes can flow just as much volume as a larger 1" pipe. And several smaller faucets can flow as much as a large hydrant.
The "question" inferred by the OP in the thread title is that of the FU being "too restrictive". Ummmmmm ... not it's not. Now, if he asked if it was slightly more restrictive than some other choices, and then he had flow data to back up his assertion/question, I'd have to say he did some homework at least. But that wasn't the case. He's not reasoning; he guessing. As are you. And it's no more clear than your comment about the size of the holes; that does not speak to the flow, but only an area of a singular hole, not total holes for total flow.
Fram does not publish their flow data unless asked, but Wix puts up the data for all to see, and he asked about those too. And clearly, despite the large variation in efficiency, the flow ratings are the same between Wix and Wix XP.
THE POINT TO GRASP IS THAT THE FLOW RATINGS WE SEE, AND EVEN THOSE WE DON'T, EXIST IN PRODUCTS DESIGNED TO BE MORE THAN SUFFICIENT AT WORST CASE.
Seriously, is it really someone's assertion that a top-tier product is actually "too restrictive", even though that product is now rated for up to 20k miles?
