IF you have the Hyundai 2.4L GDI engine then that is good to know ... I have read here that Fram re-designed the Ultra series oil filter (XG9688) for the Hyundai engines to be more robust to handle the supposed oil pressure spikes this engine can incur . If the Extra Guard and Tough Guard have the same shell construction to handle Hyundai 2.4L oil pressure spikes then again , that is good news .FWIW, I run the Fram Extra Guard 9688 every oil change in my Hyundai. I dump the oil every 4,000 miles since I fall into the severe service category, which by Hyundai standards is 3,750 miles.
At least we've not seen end cap separation with fiber, I'd consider them superior unless it is a wholly synthetic media. In that case metal caps are necessary.The Fram Tough Guard could be a sweet spot using synthetic oil in the Hyundai 2.4L engine for a max 4,000 ~ 5,000 mile OCI . I believe the Tough Guard uses a card board end cap which may or may not be a reason for concern with the Hyundai 2.4L GDI ? If the Fram contact indicated that all series of the Fram #9688 were re-designed to be beefed up then most likely the card board end cap was taken into consideration ?
I believe it was the burst pressure, aka. filter can strength, and rubber gasket design(??) that was beefed up on the xx9688 lineup. AFAIK none of the internals were beefed up, nor were they needed to be beefed up.If the Fram contact indicated that all series of the Fram #9688 were re-designed to be beefed up then most likely the card board end cap was taken into consideration ?
So if burst pressure and rubber gasket design were beefed up across the Extra Guard (Orange) , Tough Guard (Silver) and Ultra (Gold) oil filters in the XX9688 series line up then not much of a reason to look any where else for a comparable oil filter (especially one I can loosen by hand with Fram grip surface) .I believe it was the burst pressure, aka. filter can strength, and rubber gasket design(??) that was beefed up on the xx9688 lineup. AFAIK none of the internals were beefed up, nor were they needed to be beefed up.
