Good Morning Board,
I contacted Fram asking them for the efficiency of this filter and the good folks at Fram responded with the following:
Hello Frank,
Here is the information on that filter -
· at 10 microns filter is 50% efficient (referred to as nominal micron rating)
· at 20 microns filters is 85% efficient (Fram standard used for micron rating because particles above 20 micron can cause engine wear)
· at 25-30 microns filter is 98% efficient (referred to as absolute micron rating)
Thank you for contacting Fram.
I've examined this filter at Walmart, the core is "holes" not "louvers," and from some YouTube Videos, it is an extremely well built product.
Plus, I so appreciate the transperancy of Fram to provide the consumer with information on their product - other manufacturers should take note.
I've used Fram products over the years, never an issue.
I thought the motorcyclists on the Board would appreciate this information.
RevRider
Hello Frank,
RevRider
