Seems you're lacking knowledge on how a simple filter bypass valve works. What are you talking about in the bold? An oil filter bypass valve is nothing more than a pressure operated valve. It simply moves/opens because of a pressure difference across it - it's only the delta-p that overcomes the spring pressure and makes the valve start to open. Fluid pressure delta makes things work ... it's simple fluid dynamics.So... the media pushes a small finger against the spring?
Where is the energy coming that will be stored in the spring? Try to keep a spring compressed and see if it takes an effort. The only source of energy is the fluid moving around the valve. And that fluid will lose pressure at the back side of the spring loaded valve surface. Valves are just restrictions that have local pressure drops, that's why you can turn the water flow lower in your house sink.
Seems you're lacking on how fluid dynamics work. LoL ... "teach me basic physics". Thanks for the laugh, I needed it.As for the filter, at that point in oil's viscosity... it's a brick. Try pushing honey trough a coffee filter paper - nothing goes by. That's why we have those valves installed there in the first place.
I'm not gonna teach you basic physics. Have a nice day!
