Theres several questions one may consider when using Frams.
1.Will they destroy an engine?
The answer is;No,they probably wont.
Neither would an empty filter can destroy an engine in a fast obvious way.
2.Are they made cheaper than the rest?
Maybe,maybe not.There is a new filter construction on the market that is similar to Fram.
While cardboard isnt used,there is a bonding used between two similar filter materials.
That's the old "look over there" argument.
Two sow's ears don't make a silk purse
3.Does the amount of filter material in a filter mean anything?
Once again,this is a maybe maybe not.The type and quality of the material means more than the actual amount used.
A filter may have 200 sq.inches of type A filter media that is a basic filtering material.
Filter B may have 110 sq.inches of type B filter media that is a higher standard in filtering material.
You cant always go by the amount of media.
We consumers don't have much useful information on media. Lacking that information, it's logical to assume that a company that cuts corners in obvious ways cuts them in not obvious ways. Fram uses better quailty media??
4.Are Frams overpriced?
Possibly,it seems that several think so.
5.Does the actual construction of Frams mean that they are a bad product?
Probably not,they seem to be constructed as well as some others.
The old "look over there argument again".
The quality of the products used in construction may not be to the liking of some.
No disagreement there.
6.Have you or do you personaly know anyone that has had an engine damaged by Fram?
This is not a 'my friends gilrfriends uncles friends friend had a Fram blow up their engine' type question.
This is a first hand knowledge only question.
I don't personally know anyone who has died as reuslt of driving down the wrong side of the freeway either. I have read about a few and after some deep thought about the practice have choosen to not do it.
7.Are there better filters?
Yes but if one changes their oil with 3K OCI's,is a different filter needed?
No filter is needed if your standards are low enough. A more useful question would be "Are there worse major brand name filters?"
What I dont like about Fram is the small oil inlet holes that the filters have.
That's the least of their problems. The total hole area is reasonable compared to the rate of oil flow in an engine. The oil velocity through the holes is within the limits of good practice.
