Exactly ! That's the reason they put that coating there.The grip is supposed to help in that endeavor.
I tighten all filter makes by hand. They don't leak. Imagine that I'm 77. I don't need to bust a gut to get them off!How do you install a fram filter with the grip? Can you use your hand or do you still need to tighten with a wrench?
That is exactly what I do. Just a small nudge with the filter wrench. I have seen too many leaking filters because the were only hand tight and I don't need that in my life.I've always given any spin-on oil filter a small little tighten with a oil filter wrench. By small I mean about 1" tighter. Never had a problem with loose, leaking, won't come off or gasket sticking. I've had numerous new car oil filters that I destroyed getting them off.
