I think your engine will be fine. If you're anything like my experience, the other parts and pieces of the vehicle will wear out and need to be replaced and/or the vehicle moved on long before the engine has a serious issue, let alone fails. Especially so with the regular oil and filter changes done by bitog member/ readers. And, how many folks regularly use OEM filters like Toyota/Honda and what's known about their efficiency. So, it'll be ok.I decided to keep BOSS filter I bought, I hope my engine does not blow up.
The official spec sheet for the Boss PBL22500 from M+H says it's 99% at >46u. So you have 3 sources for the same PBL22500 filter model: M+H spec sheet, Ascents ISO testing and BR's test ranking - all tested the same PBL22500 filter model. To add, the M+H spec sheet for the PBL30001 ISO efficiency claim does not match the ISO claim on Purolator's website for the same filter model number. So you have all this information on the Boss efficiency that doesn't match up real well and nobody can say for sure what it really is. If I had to believe any source(s), it would be the M+H spec sheet and Ascent's ISO testing because those sources are based on an official ISO 4548-12 efficiency. It could be somewhere between those two data points. Even it it was 97% @ 30u, it still shouldn't have ranked as high as it did in the BR ranking. People comparing all the sources will have to make whatever they want out of it and decide.Ascent graphs say its 30um at 97%, thats pretty good too
You'll be Ok ... but I wouldn't use it for a long 10K OCI because low efficiency filters are low because they shed (slough off) already captured debris in the media as they load up and the dP across the media increases. That was shown by Purolator/M+H data and also in Ascents ISO testing. People that do long OCIs (or using the same filter for X number of shorter OCIs) will benefit by using a higher efficiency and holding capacity filter.I probably wont buy it again, but I am sure my engine will be fine
Still sad to say……maybe say Ram truckOne would assume he's referring to the fact that it's "Cummins" (no "g" in the name).
Will you also have a particle count on the same engine ran with the same oil brand/grade and the same OCI under the same use conditions using other filters with different ISO efficiency? That's the only way to get a decent comparisonIm having a particle test done with the BOSS, PBL14476. I'll post the results
Nothing is ever good for you, is it? It will be my engine a boss filter and HPL oil, and that is good enough for me.Will you also have a particle count on the same engine ran with the same oil brand/grade and the same OCI under the same use conditions using other filters with different ISO efficiency? That's the only way to get a decent comparison
It's simple testing protocol. Without some testing control, you'd have meaningless information ... that's just basic simple logic regardless of what you think it is.Nothing is ever good for you, is it?
Sorry it's not with your favored Fram filtersIt's simple testing protocol. Without some testing control, you'd have meaningless information ... just basic simple logic regardless of what you think it is.![]()
LoL ... so you really think the Boss has equal or better (or even close to) efficiency of the Endurance? If so, why? ... and how are you going to show that it is? With a PC with nothing else to compare it to? Ascent (the RP and FE are basically the same) and M+H/Purolator (via Spec Sheet info) say that it's not, so you don't believe them, or rather believe some YT home-made test setup? Which you can believe if you want to.Sorry it's not with your favored Fram filters
This seems to be a common theme but I’m not really sure why.Do you think a slightly better filtering efficiency is really going to matter? And the quality of the BOSS is far superior. I'll easily get 250+k miles from my engine on this filter, so that's all I need to know. Go BOSS!
10-4 … And we went through that with not just brands but certain models within the brand - hats off to the filter cutters without the snide remarks wrt beauty pageants …The key is not to get emotionally attached to a brand. After 20+ years of running wix filters I had to let go. The quality was no longer there. Also realize YouTube is for entertainment purposes only.
