Fram Endurance Flashlight Test in canister
I've never watched BR's reviews. If ISO test results are available with the efficiency results listed on the packaging, I'm good with that. We all make our choices for whatever reasons. It's funny how I was OK with Purolator tears, justifying in my head, "well, it surely isn't all of them" but here, this gap situation troubles me more. Not logical, but where I am.
I don’t think this bypass GAP is “hit or miss” as it would be with a torn media.
It appears this “GAP debacle” is present in virtually all models that have this identical bypass make and design…at least those manufactured since Jan of last year.
We’ve already seen this in Fram…Amsoil and Supertech filters as far as flashlight testing. I suspect if someone performs the test on a Royal Purple, we’ll see the same results. The GAP is inherent in the design and materials of this bypass. Of course I’ve stated MY OPINIONS here on how this probably impacts bottom line performance.
You should watch the BR video reviews especially on the Fram comparisons. Their newer rig is quite sophisticated and I posted a vid here that explains their testing procedures. In the PARTICLE TEST, they special ordered the ISO sanctioned particle kit…which cost them a pretty penny!
It all comes down to what you’re comfortable with. I have no reservations about using the Fram Endurance gaps and all.
Here’s the video explaining testing and particle kit
Particle Kit :
Foot note:
The Royal Purple is the only one in this video that has same bypass as Fram/Amsoil. It’s seen on far left here.The rest are integrated on the TOP. Nonetheless, this filter performed well on particle test. Caveat…we don’t know if it had a bypass gap or not 🙄🥱
Whatever else we think of Brand Reports youtube channel testing, it was interesting how bad the TG & PH were. The PH is one of the worst ones they've tested and even has particles above 70 micron in size which almost no other filter recorded. The TG performed only slightly better than a WIX XP.
The accuracy of their rankings has not been verified through official test standards like ISO 4548-12 for comparison. In fact, some of their ranking order contradicts the results of official ISO 4548-12 information from the filter manufactures. They should also include careful visual inspection for leak gaps after they test, as filters that rank noticeably different from what their ISO spec says may be because of a leak in the specific filter they tested. Like the PH they tested ... it could have had a leak gap on the leaf spring due to the end of the center tube interference like seen here a few times.
Edit ... here's the video, and the PH did have a suspect dirty oil leak path. So that right there could have been the cause of the bad PC count.
Yes, a completely different problem than Endurance leak though. Looks more substantial (see pic below). Also, the results of the PH are from a cellulose blend media vs say the WIX XP which is synthetic blend, and that showed about 1/2 the amount particles (21-38 microns) of PH, which is about what you would expect? So, I’m not so sure that you can attribute most of that PH particle result due to that leak path vs inadequate media
PH filter GAP:
The ISO 4548-12 efficiency difference between a 95% @ 20u (the PH) and a 99% @ 20u (the Endurance) filter would not be the main reason for that bad of a PC difference. The leak path in the Endurance discussed in this thread was calculated to be around 16% of the flow going into the filter, which IMO isn't really "insignificant". Like said a dozen or more times, you'd have to test the effect of a leak path in a controlled manner to know the actual impact on the efficiency. Of course, the larger the leak the more impact it will have.
“The ISO 4548-12 efficiency difference between a 95% @ 20u (the PH) and a 99% @ 20u (the Endurance) filter would not be the main reason for that bad of a PC difference.”
Ok, let me ask you this then. Correct me if I’m off base. The lower rated PH filter would continue to allow a greater passage in that particle range to ACCUMULATE in the oil with subsequent passes and so the effect becomes ADDITIVE and COMPOUNDS over time. That 5% doesn’t seem like much, but it accumulates quickly given 5 passes of total volume per minute in an average motor?🤷
Yes it would have been great if they opened and inspected all the tested filters.
The ranking that carries the most weight is that done by Ascent. It is my understanding that you can't compare one manufacturer to another since the ISO standard allows for different parameters to be chosen by the manufacturer / tester.
We also know that different filter models test differently to other ones that presumably have the same media and same design.
Also, do you know if the Ascent efficiency testing and ISO 4548-12 efficiency testing in general was / is done on the element only or the filter as a whole?
There is a big # of particle difference between a 95% efficient filter and a 98.7% efficient filter:
Now that’s revealing. Looking at WIX EP vs Fram HP results are about 2X ratio for 95% vs 99%. The chart 95 vs 98.7 would even be greater at almost 4X. In any event, it appears then that the poor HP can be attributed to the filter rating alone.
Yes, Ascent tested the whole filter, just as it would be mounted on an engine in real use. If you haven't read the Ascent ISO efficiency testing thread, you should.
The difference in particals/ml between 95% and 99% efficiency is around 4 times more particles with 95% filtering efficency.
The level of particles/ml difference between the PH and the 99% efficient filters in the BR tests was more along the lines of around 78 times more at 21u and higher. That's pretty huge, so that tells me the PH was probably a pretty good leaker. The shown gap on the PH most likely the cause.
If you went off the table in post 488, there should be around 4 times more particles/ml if you used a 95% @ 20u vs 99% @ 20u filter (non-leakers) for the same exact OCI under the same exact driving conditions (ie, same exact level of debris generation into the oil over the OCI).
This is why I've said many times in filter efficiency discussions that the longer the OCI, the better it is to use a higher efficiency oil filter.
“If you went off the table in post 488, there should be around 4 times more particles/ml if you used a 95% @ 20u vs 99% @ 20u filter (non-leakers)”
Lol…
Yeah …,Endurance is probably greater than 99%, but these #s are all over the place. Look at WIX claiming 99% and it’s not even close to Endurance!
What I’m saying here is that Filter efficiency trumps any potential counter defects …aka…bypass flaws. You have a “ Gate Keeper” that keeps the numbers from running out of control.
We’ll have to await any definitive test for an answer, but the overwhelming efficiency of the Endurance will , in my humble opinion, minimize any pesky leaks from gaps.
Yeah….round and round we go….
Well, that seems pretty obvious.
It all depends on the size of the leak, the contamination level of the oil and the efficiency of the filter media. Many factors involved. A constantly leaking filter is decreasing its efficiency, and the larger the leak the more impact it has on the effective efficiency.
But the bottom line is filters should not have leak paths like the ones seen. Just like filters should not have torn media, which is another type of constant leak path.
This broken ecord has been smashed over the dead horse's head. 😆
No one in their right mind would rally around any defect. So I’m all in for any improvements.
Yes, A leak decreases it’s potential efficiency, but it’s still superior until proven otherwise , so…..
Does it warrant taking action and replacing it with another?
The decision in this case is a no brainer for me. Still the best filter on the market.
😆 No one in their right mind would rally around any defect.
Nobody really knows just how "superior" any leaky filters is. Maybe it's the most "superior" leaky filter in the market. 🙃 😆 Nobody would know without controlled testing. 🐎🐴🔨
Burden’s on you to refute and prove current current claims by Fram (and BR results) are invalid. Finding a “potential leak” doesn’t refute those results does it??
I’ll let current results do the talking until you can prove otherwise.
Ball’s in your court.
So GasLight to your hearts content…
How many times have I said I make no such claim one way or the other - so I don't have any claim to.prove. The efficiency tested filters could have been non-leakers or leakers - there's no proof one way or the other. My only claim is that nobody has any real test data that correlates a leaky filter's impact on the efficiency compared to the same filter not leaking. So no proof one way or the other has been shown.
You however think that the Endurace was a leaker when efficiency tested. Therefore the burden of proof is all on you to prove that thought/claim. You only gaslight yourself with speculation and fanboyism to believing things that have no proof.
Frankly, I don't know why this thread hasn't been locked by a Mod by now. It's gone round and round over the same points way more than any other thread that's been locked for much less repetitive discussion merry-go-round.
