Fram Endurance Flashlight Test in canister
Note the last sentence
“However, according to the test data, they are still performing as prescribed after the manufacturing change.”
From BR results, late last year. In FILTERING…not talking about overall rankings…..
Amsoil came out #1 and Endurance was a tad behind #2. No surprise, they’re essentially the same filters.
You can bet your A$$ that they had “gaps”😉
Again ....
Don't judge the filter's seal in the dissected state; that's not a fair assessment of its operational condition. We cannot see inside the "as built" can, but we know that the leaf spring's job is to force the spring/BP assembly into the end cap. Does anyone here have the spec of the "as built" can? Do we know how much force is applied? Do we know the dimensional tolerance stack-up? I suspect no one here has these answers, but many of you are willing to condemn a product by judging it AFTER it's been altered (torn apart). That's not applicable to the "as built - in operation" state.
There are things we can deduce from taking a filter apart, but the seal of the leaf spring to the end cap ain't one of them. That would have to be judged in the "as built" state.
(sigh ......)
Endurance is leaking “as built”
Again, we're told this is normal for this filter at this time, however, due to some other conversations had, we're leaning on the supplier for a little better explanation at this time. However, according to the test data, they are still performing as prescribed after the manufacturing change.
Thanks for this. What catches my eye is “normal for this filter at this time”. Seems like they are aware of the defect and may be working on a solution.
Something is afoot
Sounds like Amsoil is being cautious with what they say, but leaving the possibility that we may be onto something. They are not being definitive:
“however, due to some other conversations had, we're leaning on the supplier for a little better explanation at this time.”
The last sentence here still makes sense *IF* this is a defect and retesting has not occurred due to an unplanned flaw. Obviously, data is still data but what is the context and the screenshot? When and which filters? They did not say “we have retested the filters with this leak and performance is the same as before; data unchanged…” the below indicates acknowledgment of a design change. Flawed manufacturing of the change is a different conversation.
“However, according to the test data, they are still performing as prescribed after the manufacturing change.“
My best “guess” is Champ Labs is falling back on iso results. Again no way to know if the tested filters were leakers or not or when the iso testing was performed. I believe Fram, RP, and Amsoil rely on CL for testing this line of filters. No doubt even without a seal but with properly stamped leaf springs this would perform as specified.
I’m leaning not as some have seals and the ultras/titaniums don’t leak even without seals.
It’s more UNLIKELY those tested don’t have gaps and don’t leak. Show me an Endurance/Ultra or equivalent Amsoil cut open without a gap.
Another point …Im convinced the speculation that… “10% of total flow through the filter is bypass leakage getting through” ….is bogus.
The gap under the leaf plates is not the same as a space of an equal area located on top adjacent to the valve itself. The direction of flow is completely different.
Being located UNDERNEATH the plate results in obstructed flow as opposed to direct flow if located on top near the valve itself. Same with the analogy of a “hole in the filter” itself.
Fact of the matter it’s all pure speculation, but as I point out, ACTUAL test results point to the notion that these filters still perform very well, gaps notwithstanding.
You don’t have proof of your conclusions and are taking what is said at face value. Either you are concerned or not. You believe based on faith; not 100% unbiased data. Until someone tests a known leaker and the data is verified; it’s all guess work. A need to be right here doesn’t make you right; which in the end there is still that possibility. Drawing conclusions and making leaps of faith is blind until otherwise proven.
Exactly! Is a gap and the passing of unfiltered oil by design? Common sense says no. That is why we are awaiting an explanation. so far, indirectly answering. We have seen media Tears become common in the past. Did that mean the testing for that filter line was still valid? This still sounds like a PR response under the pretense of a technical answer. They aren’t going to throw themselves under the bus. Amsoil shouldn’t, as they are not the supplier, and Champ Labs won’t publicly address something directly. This isn’t a big enough story, where we need engineers to cross examine lol.
We also know that the three iso tested Endurances have different leaf springs than the FE 7317. We’ve only seen leaking 7317’s and the equivalents so far with no official or garbage tests on them.
Testing this Fram filter in an "opened up" state is NOT the same as judging the "as built" state.
The force of the spring seated against the bottom of the can will push the leaf assembly firmly into the fiber end cap.
Unless in the case of the PH shown here where the end of the center tube is preventing the leaf spring from seating all the way down on the end cap.
The "seal" needs only to exist in a very small area. It would be wrong to assume that the seal is needed fully around the flat circumference interface; it can exist around the radiused intersection of the end cap and leaf where it protrudes into the cap.
From what I see, no leaf spring is sealed around the radiused intersection - except for perhaps the OG Ultra with the fiber seal ring in the end cap. In other cases (like the others seen in this thread), it's always on the top of the end cap surface. If that interface is not flat an smooth in the case of metal-to-metal seals, then there will be leakage.
Yeah, I have never seen these “leaf springs” show stored energy like cutting an old Wix with a coil spring … The PF63 I just cut had no separation force just like Fram’s don’t …
There's some, you just can't notice it like a compressed coil spring. The leaf springs have a very high spring constant, so they only need to deflect a very small amount to get an adequate compressive force. A coil spring needs to compress way more to get the same force, so they "spring" open more when the compression force is relieved. If the leaf spring didn't compress and hold the gut tight together, you'd be seeing a lot more filters that "rattled" because the guts weren't tight.
Yes, been seen here before. When the endcap deflection/distortion reaches some point, there's no saving it from oil bypass with the stamped spring pressure inside the can. May or may not be the case in the pic. But definitely the case in the linked below TG3614 anecdote. Fwiw, I've seen others but this one most comes to mind.
https://bobistheoilguy.com/forums/threads/fram-tough-guard-3614-cut-open-internal-damage.270870/
That looks like another case where the end of the center tube interfered with the complete sealing on the end cap.
Again ....
(sigh ......)
This thread original postings was with a look at the leaf spring gap inside an assembled filter. Still a gap. As mentioned many times, even after cutting the filter open, putting a lot of force on the leaf spring ears does not close the gap because the section of the leaf spring the seals on the end cap is too stiff to deflect. Instead, the leaf spring ears will bend before the sealing area deflects.
As I said, this is all still speculation. I was talking about what I thought was most likely/unlikely. Likely the results on testing came from the filters in question that had the bypass imperfection. The test comparing Fram models (shown below) are from late last year, well AFTER the dates of manufacture that failed Whip City flashlight tests on an Endurance filter. Bingo. So, NO…I’m not saying the Endurance results shown here had the defect …there’s no way of knowing….but MORE LIKELY than not. To date NO FRAM ENDURANCE or ULTRA filters that were made from last year on, have passed a flashlight test.
Fram models on particle filtration less than a year ago.
Note the last sentence: "However, according to the test data, they are still performing as prescribed after the manufacturing change."
Still, there is no real test data that correlated a leak to the effect on ISO efficiency. Nobody (Ascent, BR, whoever) has shown how a leak seen in these leaf springs effects the ISO efficiency. But on thing is certain, if there's an obvious gap there will be a leak.
