Agree!i’ve cut open a lot of new and old titanium’s. i can assure you that the gasket doesn’t exist.
the media will absorb the oil.So I just tested two XG2 both manufactured Plant A June 25th 2024 Shift 1.
Using a funnel, I poured M1 0w40 down the center hole.
Within minutes, both drained through and therefore FAILED.
I have another one arriving in a week. Let's see if it is a different date code. If so, I will test it. In the meantime, I will contact Fram.
Seriously though, shouldn't Fram be doing such a test as part of QA?
Shouldn't anyone doing ISO testing be doing such a test both before and after a filter is tested? It is such a simple check on filter integrity.
EXACTLY WHY I ASKED HOW MUCH OIL WAS POURED IN.This just dawned on me.
If you filled the tube, how much of that would be absorbed by the filter itself?
Could be substantial?
I got the impression he filled it up all the way. Guess we’ll have to await his answer?EXACTLY WHY I ASKED HOW MUCH OIL WAS POURED IN.
The only way to do this would be to remove the filter from the can. Then you can see how much came out the bypass end vs what was poured in.Is that what you did? Hard to tell from the close ups. I assumed it was an intact filter.I showed you here: (No need for CAPS. Calm down.)
https://bobistheoilguy.com/forums/t...ashlight-test-in-canister.386911/post-7013113
Fair enough, so we’re looking at what? 5-10 ml gone in 5 min? Just curious.Here is how much I poured in. I took this photo immediately after pouring in. I used a funnel so the oil hit the black poppet valve
i believe this test to be a valid test but the results are inconclusive. you’re going to have a leak with metal on metal sealing unless there is perfect fit ups and tons of pressure. oil filters have been built like this for a long time. sure id love to see first brands go to a one piece cap with an integrated bypass and a coil springs but i just don’t think it’s necessarily a con towards them that they don’t.Fair enough, so we’re looking at what? 5-10 ml gone in 5 min? Just curious.
I wasn't excited or yelling at you. I was telling him that is why I asked, things get buried in this long thread.I showed you here: (No need for CAPS. Calm down.)
That's how you pre-fill a filter before installation.This just dawned on me.
From what I see, looks like he filled the bottom of the center tube just enough to bring the leve just below the center tube louvers and the black bypass valve. Although, looks like some louvers are touching oil, so could have been some leakage there. Not much oil depth, which means virtually no head pressure dP.Hard for me to tell in the pictures the volume of oil at T=0. There definitely could be weeping/soaking at the media.
Yes agree. I mean there COULD be if a lot of oil was poured in. That is back to and why I asked how much in the first place.From what I see, looks like he filled the bottom of the center tube just enough to bring the leve just below the center tube holes and the black bypass valve. Not much oil depth, which means virtually no head pressure dP.
If you're going to be doing PCs, I would suggest using WearCheck instead of Blackstone.Unfortunately, this would be my first particle count. If needed, I can swap to a different filter for my next OCI. Not sure if/how I can help here. But, willing to take guidance/requests on how to proceed, if there’s any value to be gained.
Exactly, that’s why I just had my “Epiphany” on the matter. LolYes agree. I mean there COULD be if a lot of oil was poured in. That is back to and why I asked how much in the first place
That could get messy depending on filter position…That's how you pre-fill a filter before installation.![]()
The new one has 36 pleats.@Fair enough - can you count the number of pleats? The pink media had 36 pleats but Fram said that the updated Ultras had more pleats to increase the holding capacity to compensate for the new media not having as much depth holding ability.
I pre-fill a filter that is mounted vertical with the base down (4.0L V6 Tacoma) and don't spill a drop. Just need to know how much pre-filling you can do without making a mess.That could get messy depending on filter position…
