Originally Posted By: buster
Ah the good ol 4-ball wear test.
It's used as a "pre-screen" for certain additives and is a very simple bench test. Very poor correlation to real world engine testing, so I was told. I could be wrong about that, but that is what I found. I don't fault Amsoil for using it. It does have some validity to it for screening/testing AW additives.
You never want to rely heavily on bench testing. It's a decent machine that can give you some idea of wear performance characteristics, but is extremely limited in what it can tell you.
If the 4-ball wear scar was that important, all other companies would formulate so they achieved a good 4-ball wear scar. They don't. They have been ignoring this test for years and years.
Apparently both TFOUT/4-ball wear machines collect dust at most labs and are not used anymore. Much more sophisticated and expensive testing is available now.
Well put Buster.
The 4-Ball test is a perfectly valid test for measuring wear properties of lubricants under a specific set of conditions and metallurgy. It doesn't matter what type of lubricant it was developed for - grease and gear oils are lubricants, and a test can be valid and useful for different types of lubricants.
That said, there are different types of wear and many different types of wear testing machines, each operating under their own unique set of conditions. These different wear machines can and do rank oils in different orders, because oils perform differently under varying sets of conditions. This is why lubricant formulators use multiple wear tests to characterize an oil's performance in varying environments, rather than relying on a single test to tell the whole story.
Assuming you already have the machine, the 4-Ball test is a cheap and fast test, and so can be used to screen numerous additive/base oil combinations for relative wear under one set of conditions. This is useful for a formulator to get a feel for how ingredients are behaving before moving on to slower and more expensive wear tests.
Motor oils are exposed to many different wear types and environments in an engine, requiring different wear additives and different wear tests to evaluate them. The industry has settled on certain engine tests as specified for the API certifications. Oil and additive companies have their own in-house proprietary wear tests developed to correlate to these engine tests, so that they can play with various ingredients and ratios before committing to expensive engine tests. The 4-Ball test is not highly respected in the industry for correlation to engine tests, but still has some value in the formulation process.
Bottom line, one should not draw conclusions on a motor oil's wear performance properties based solely on any single wear test. However, a significantly poor result in any one wear test warrants further investigation.
Tom NJ
