Found A Good Use For Used Motor Oil
I was told oil is recycled by a friend's father who was an electrical engineer. How much he knew about the oil refining industry is questionable.
It was "common knowledge" that Sears oil was made from recycled oil. I have no idea if that was true but the same poppo told me many swore by such oils as lesser grade stuff was gone from the recycled product.
Recycling should be total.
Valvoline NextGen was a sales flop. People, Americans at least, don't trust the process.
Used oil heaters are common here. With #2 HHO at $5.25/gal I'm jealous. But since they're engineered for it, they get hot enough to burn it "ok". Not sure doing it with a match is the same.
If you dump it into the streams and rivers it gets evenly dispersed back into the ground to be found again.😳
Better than this.
