I have an old dump truck with a Cat 1160 (similar to but predated the more well known 3208). This is a V8 naturally aspirated, mechanical FI, non-sleeved diesel engine. It usually sees a little duty every year but the miles are really low.
Only a couple hundred miles on the last oil change, but also a couple years. When it does run it it will run long enough to get the condensation cooked out. Currently has Delo 400 (non-synthetic) 15W40; and with the low miles this is not even near sooty. The engine also sports twin oil filters (have Donaldson filters on it).
I'm guessing the right thing to do would be to do an oil analysis on it and go from there, but that's almost half way to an oil change dollar-wise.
Are there any additives that are typically used in situations where you will have too much time but low miles on an oil change?
