Ford Racing Oil filter vs Motorcraft (repost?)
KDS
PA
These are the specs of the Ford Racing and Motorcraft filters for the Mustang 4.6L
Ford Racing CM-6731-FL820 Oil Filter
Measurements
* Filter Weight - 19.75 oz
* Can OD - 3.68" / Seam OD - 3.76"
* Overall Height - 3.99"
* Can Material - 0.019" thick steel
* Filter Element OD - 3.44" (at element)
* Filter Element Height - 2.81"
* Media - Cellulose - Synthetic Mix? Oiled? (appears orange)
* Number of pleats - 63 + 1 joint
* Depth of pleats - 0.73"
* Media length (unrolled) - 100" (seam crimped)
* Media width (glue not included) - 2.50"
* Media thickness - 0.029"
* Total media surface area - 250 sq. in.
* Total media volume - 7.25 cu. in.
* Inner Filter Support Material - 0.010" Thick Perforated Steel
* Inner Filter Support OD - 1.71"
* Indentifying marks
Can - 810050516 / Made in USA
Bar Code - 7_56122_07567_8
Label - 6945234
Base - 22 / MM
* Gasket Retention - Multiple Crimps
* Thread - M22-1.5
* Relief Valve Location - base end
* ADBV Material - Silicon
Motorcraft FL-820S
Measurements
* Filter Weight - 13.1 oz
* Overall OD - 3.76" @ seam / 3.66 @ can
* Overall Height - 4.05"
* Can Material - 0.02" thick steel
* Filter Element OD - 3.25"
* Filter Element Height - 2.51"
* Media - Cellulose (appears pink/orange)
* Number of pleats - 43 + 1 joint
* Depth of pleats - 0.68"
* Media length (unrolled) - 65.5"
* Media width (glue not included) - 2.375"
* Media thickness - 0.035"
* Total media surface area - 156 sq. in.
* Total media volume - 5.4 cu. in.
* Inner Filter Support Material - 0.012" Thick Perforated Steel
* Inner Filter Support OD - 1.68"
Can - Made in USA
ADBV - 6944453 / AAX / 150
* Thread - M22-1.5
* ADBV Material - Silicone (orange)
I'd say so too. If you're going to be flat shifting @ 7000+ (or wherever) and stressing things beyond normal ..go with the most robust can you can find.
Where would you buy this Ford Racing Oil Filter, someone wants to Drag Race against me next weekend.
Cheapest place is thefordsources.com about $12/13 a filter +s/h so get about 4-5 of them, otherwise its a like $130 a case.
Unless your laying down some SERIOUS HP its not worth it. I'm putting down 398HP and 481TW to the wheels with a ProCharged "stockish" 355 TPI Camaro and run the stock purolater filter. The oil pump spring will release pressure before its too much.
LOL You're just hating because you drive a bowtie.
I agree w/Mkos1980. Unless you're making serious HP and have massive oil pressure, the racing version of the FL820S is a total waste of money.
As for burst strength (which isn't listed above), unless it's a typo the can material for the plain jane filter is .001 thicker than the racing version.
