Ford Mercon Lv compatibility
Buddies 17 Passat with 6At , believe it's a asin transmission . OEM is a LV fluid , any thoughts on using the Motorcraft LV ? I see people using the Valvoline for everything fluid was seemingly no issues . It's actually his daughter's car .
Sometimes the better question is not “can” you do something but more “why” would you do something.
Fluid that meets whatever spec or at least claims on the bottle to be compatible is readily available at a similar price, right?
Well I have 13 qts of the Motorcraft LV I'd like to make disappear.
My 2017 Ford Fusion calls for LV ATF. I only used M1 LV HP atf and the trans shifts great up and down. I do the drain and fill every 30-35 K and the fluid drains out very clean as apposed to the MC LV fluid which drained out very dark the first two D&Fs I did.
I have no idea but post up what you do and if possible long term results should you choose the Motorcraft
