Scott S
Find out tomorrow LOLThe OEM timing chain has been on back order on and off lately. Not sure if it still is.
The primary, BL3Z-6268-A and secondary, AT4Z-6268-A, for this application are readily available. Now any of the other components, I would have to check. Ford does not make a "kit" for these and everything is sold individually. I usually keep them all in stock since anything of this vintage we do a water pump on usually gets a timing set as well.
There are a bunch of different part numbers for the timing chains. I try to keep them all in stock for my service department.Good to know. Not sure we just waited over a month for 2 timing chains for 2 different explorers.
I should do a 2023 - labor rate thread, but ALL of the dealers around here just bumped their rates to the low/mid $200 range.
Same could be said about most large metropolitan areas, but yes.In a place where a shack only worthy of a tear-down runs $800K plus, right?
I have a 2018 Edge with this engine. Watching this engine water pump design gives me the willies.
That's why I'm doing it out of preventive maintenance, anytime I change the oil I always take a look at the weep hole, anytime I checked the oil I always look for coolant, I sent oil samples out, I've even put oil samples in a frying pan before..I have a 2018 Edge with this engine. Watching this engine water pump design gives me the willies.
Seems idiotic to have a weep hole drain into the engine. Imagine if post op they routed your foley catheter into your nose. Duct the d*** water pump outside the engine.
Morons
Honestly -- and this is only my perception -- I always figured it was a heritage/corporate culture issue because Team Duratec always seemed to build a V6 and then realize they forgot the water pump.I think the issue was they could not physically fit the engine in transverse applications with an external water pump. Which is why they put it inside
Doesn't that depend on the year? Before a certain year, they did that. After a certain model year a spot was made in the pump for it to leak out externally. For a 2011 3.5L Ford Edge, if the shaft seal starts to go there tube for the coolant to drain externally:because the water pump is inside the timing cover and if it leaks coolant goes directly into the oil and destroys the engine. Ford's transverse 3.5 is known for this. Take the labor cost hit once.
The timing chain rides on water pump.. there is a weep hole for it to leak externally but it can also go the opposite way and go right into the sump..There are lots of YouTube videos on how to change out this water pump. Yes, it's difficult by water pump standards, but I would think that most people here could do it. Personally, I wouldn't change out the timing components unless the engine has high mileage Or I saw an issue.
The previous gen 3.0 hung it off the back opposite every other engine driven accy, driven by its own standalone shaft like a PTO.....in a cheesy plastic enclosure.
The 3.0 solution was arguably crude but effective and easy to service
The 3.5 went to the other extreme and while arguably elegant from an engineering perspective was NOT elegant for maintenance or mode of failure. Milkshakes are bad...
But point being: two consecutive generations of V6s with the Duratec moniker where I just feel like the engineers didn't know what quite to do with the water pump![]()
Thought I'd add my 2 cents or perhaps more confusion. We had a Taurus-X. Pretty sure same drivetrain and Shakey water pump design. Never replaced it and it never failed in the 210k miles we had it. Car was still in good shape at 200k so replaced Pto then that failed (yes changed fluids there) and ended up junking it at 210k when transmission failed but water pump was still good. May consider leaving it be and just taking your chances.I have a 2013 Ford Edge with a 3.5 with about 120K. I'm replacing the water pump out of preventive maintenance. I'm doing the timing chains as well; I plan on getting a Cloyes's timing chain kit Motorcraft water pump, felpro gasket set, OEM front main seal, OEM crank bolt. OEM thermostat. 3 gallons of Peak antifreeze, 6 quarts Mobil 1 synthetic oil. That he recommended I change in about a 1500 miles. Mechanic that will be doing it worked for Ford for 20 years till he opened up his own shop. So he's done a few of these..It will come with some sort of TechNet warranty Two years 24,000 miles Nationwide warranty. Plugs coil packs, serpentine belt has all been replaced, stretch belt has to be replaced can't be reused. Tensioner has been replaced as well.. my question is. Is Cloyes a good timing kit? Has anyone here used them before? I know they're very well known. Cloyes and Melling..
Thank you...
