Here's the back story.
Ford issued a TSB on my transmission (Tremec 3650 5 speed manual) about cold weather grinding, so I took it in and had it rebuilt by the local dealer (2450.00 bill, under warranty). The rebuilt transmission shifts much better now.
Another TSB was released (prior to the transmission being overhauled) saying do NOT fill the T3650 up to the fill hole, make sure it's 1/2" lower than the hole.
Today I changed my transmission fluid to Amsoil's Universal ATF. I removed the fill plug first, and soon as I did....fluid began gushing out and didn't stop for at least 20 seconds. *Yes, my car was perfectly level on ramps and jack stands* Guess the technician refilled my transmission on the bench instead of the car, it wasn't level when he filled it, and possibly poured in 4 quarts instead of 3.
Seriously Ford? Can you NOT read your own TSBs?
Anyway, I got 3 quarts back in and it was exactly 1/2" under the fill hole.
If you want a job done right, guess you really do have to do it for yourself.
I'm curious as to why it was suggested to not overfill up to the hole?
