OVERKILL
$100 Site Donor 2021
Friday of last week, my cruise stopped working. Ran the cruise system self-test diagnostic and everything passed, so I knew it wasn't in the wheel or the controller.
On Monday, I decided to change my coolant. While in the process, I noticed the top of the brake pressure cruise shut-off switch appeared wet, and the rubber plug that sits in the top of the connector was pushed up.... I pressed down on it and brake fluid shot out of it!
Well that explained the malfunctioning cruise.
Went to Ford yesterday, ordered a new part. Cost was an incredible $11.00.
First thing I noticed.... It looked NOTHING like the original. And comes with an adapter harness. Here is the new switch, and adapter harness:
Here is the old switch removed:
The old switch, FULL of brake fluid after removing the connector:
The connector, soaked in brake fluid:
The new switch, with adapter harness, tie-wrapped to the already in place recall harness with in-line fuse. Big 'ol bundle of wires.
