I have had problems with my Escape air bag light for years. (code 46 and 47 both front seat connections) Ford had a recall on them, and installed new wire harnesses for free, but when I picked up the vehicle and drove it home the light came back on as I pulled into the driveway. At that point I gave up...
Here is the TSB:
Some 2001-2004 Escape vehicles may exhibit an intermittent air bag lamp on and diagnostic trouble code (DTC) B1877 and/or B1881. This may be caused by a variation in the electrical continuity between the pins of the driver and/or passenger side wiring harness and the buckle pretensioner connector. If this condition were to occur, the air bag system remains fully functional.
ACTION:
Install a replacement harness connector kit ON BOTH the driver and passenger safety belt buckle pretensioners, even if the DTC is present for only one side. The kit includes improved connector halves to replace the existing connectors on both the body harness and the safety belt buckle pretensioner.
One kit is required per side (2 kits per vehicle). Refer to the instruction sheet included in the kit for complete repair procedure.
PART NUMBER PART NAME
4L8Z-78610E22-A Connector Kit (Order 2 Kits Per Vehicle)
I decided to fix it again, and cut off the connectors under the seat and soldered the wires. That fix worked for 4 days, now the light is back. Reading the TSB, the only thing it can be is the seat "pretensioners"
How are the pretensioners causing this code? My search has come up with a possible RCM internal fault. (restraints control module) that controls the pretensioners
