- Joined
- Aug 21, 2020
- Messages
- 213
There are very few transmissions on the market that are so special that a commonly available fluid on the market won't surpass the performance of the OEM fluid. So many people think their transmission (or other component) is "special" because the mfg has stated as such but this very rarely turns out to be true. We hear it all the time, every year, for decades now.
I've never used Liqui Moly products but I'm sure if they have an appropriate fluid for your application then it would work well. I know from decades of experience (and the visible lack of published articles / lawsuits / etc) that fluids from reliable brands perform as advertised. Red Line, Amsoil, Valvoline, Mobil and even the off/store brands (OEM, MotoMaster) have never disappointed. I HAVE seen several issues that were misdiagnosed / misunderstood and were blamed on fluid BRAND and not on the fluid condition / maintenance history / electrical issue / unknown TSB.
In my most recent case, our warranty replaced CVT transmission was being actively destroyed by the firmware in the TCU that was to be updated at the time of replacement, but was not. I was able to figure this out myself, after a few years, but no amount of maintenance, service or fluid swapping was going to correct the failures of Nissan the Nissan dealer. I contacted ~ 10 dealers in my area and NONE of them were able to explain this to me or to suggest a course of action other than to order a new CVT replacement.
TLDR, high performance transmission fluids are readily available, your transmission does not require a special fluid and supporting your OEM dealer is probably a bad idea.
Agreed. In fact, I've experienced improved, smoother shifting switching to some aftermarket transmission fluids. Installed Redline C+ in a Chrysler once, and it dramatically improved the shift quality of a car.
More recently I have had good success will Valvoline Extended Performance ATF and will be trying out Valvoline Restore and Protect ATF on a Ford Fusion with the problematic 6F35.
